TwinTurbo.NET: Nissan 300ZX forum - Re: I tried another timing light and it worked...
craigz96tt
on September 28, 2012 at 3:52 PM
posted by puchy
on September 28, 2012 at 01:45 PM
Are you disconnecting the harness for the IACV near the tps prior to checking timing or do you have a blazt or consult to set base idle?
ignition timing bouncing
puchy
09:33:10 09/28/12
Check the teeth on the cas and the cam itself. (n/m)
Woody75 (Denver)
10:17:13 09/28/12
puchy
13:45:48 09/28/12
Re: I tried another timing light and it worked... -
craigz96tt
15:52:45 09/28/12
That's in the back of the engine....
puchy
17:27:35 09/28/12
Re: That's in the back of the engine....
craigz96tt
09:35:09 09/30/12
Keep in mind idle timing is very sensitive
OverZealous (CT)
16:09:34 09/29/12
